Beiträge von mrsdnf
I could not find dimensions on Cafe Husky. The head width is 2mm.
This picture was borrowed from cafe husky. The washer on the left is stock and the modified washer is on the right. The modified washer is made thicker on the end, 2mm, and has a longer boss. The modified washer was made from tool steel and hardened so they did not wear out. As you can see they cannot fall out but do wear out. I always wondered why there was so much metal in the oil filter. Now I know.
Hi honey hans.
I have two bikes that takes the 9.8mm shims so purchased a Hot Cams shim kit.
I have not replaced any gaskets or seals yet and they are not leaking. When they start leaking I will replace them.
I am in Australia and most parts have to be ordered from the factory. This can take up to eight weeks.
All the best, Moose.
[user = '365'] mrsdnf [/ user]
Is this the replaced version? As far as I know there was a replacement call from swm 2 years ago.
This screen was supposed to be the replacement one.
Just beware that the filer screen behind the clutch cover can give trouble. This is my recall screen at 25000 Km.
Check the nut is tight under the positive wire going into the starter motor is tight. You will have to undo the top nut holding the positive wire on to do this.
6mm 90 degree grease nipple is what you need.
