Da nicht im Handbuch zu finden aber evtl. für jemanden interessant poste ich nachfolgend die ABS-Fehlerliste (für das Euro 5-Modell):
| DTC | Err Dashboard | Component | Description |
C0044 |
A044 |
Solid State Relay | Relay over current |
C0045 |
A045 |
Solid State Relay | Relay shorted (stuck on) |
C0046 |
A046 |
Solid State Relay | Shorted to ground |
C0051 |
A051 |
Battery Voltage | Battery under-voltage 1 (7V < Voltage < 9V) |
C0052 |
A052 |
Battery Voltage | Battery under-voltage 2 (Voltage ≤ 7V) |
C0053 |
A053 |
Battery Voltage | Battery over-voltage |
C0060 |
A060 |
Brake Pedal | Brake pedal not applied with decel |
C0061 |
A061 |
Brake Pedal | Brake pedal always applied without decel fault |
C0062 |
A062 |
Brake Diode | Brake diode breakdown |
C0070 |
A070 |
Pump Motor Control | Bad connection or pump supply open or low voltage |
C0071 |
A071 |
Pump Motor Control | Pump ground open or motor open |
C0072 |
A072 |
Pump Motor Control | Pump FET shorted |
C0073 |
A073 |
Pump Motor Control | Pump FET open |
C0074 |
A074 |
Pump Motor Control | Pump over current |
C0075 |
A075 |
Pump Motor Control | Pump motor blocked |
C0080 |
A080 |
Front WSS | HSS short to battery |
C0081 |
A081 |
Front WSS | LSS short to battery |
C0082 |
A082 |
Front WSS | HSS short to ground or WSS short circuited |
C0083 |
A083 |
Front WSS | LSS short to ground or WSS open |
C0084 |
A084 |
Front WSS | Plausibility01 |
C0085 |
A085 |
Front WSS | Plausibility02 |
C0086 |
A086 |
Front WSS | Plausibility03 |
C0087 |
A087 |
Front WSS | Plausibility04 |
C0088 |
A088 |
Front WSS | Plausibility05 |
C0100 |
A100 |
Rear WSS | HSS short to battery |
C0101 |
A101 |
Rear WSS | LSS short to battery |
C0102 |
A102 |
Rear WSS | HSS short to ground or WSS short circuited |
C0103 |
A103 |
Rear WSS | LSS short to ground or WSS open |
C0104 |
A104 |
Rear WSS | Plausibility01 |
C0105 |
A105 |
Rear WSS | Plausibility02 |
C0106 |
A106 |
Rear WSS | Plausibility03 |
C0107 |
A107 |
Rear WSS | Plausibility04 |
C0108 |
A108 |
Rear WSS | Plausibility05 |
C0120 |
A120 |
Front NO Coils | Short to battery |
C0121 |
A121 |
Front NO Coils | Short to ground or open solenoid |
C0130 |
A130 |
Front NC Coils | Short to battery |
C0131 |
A131 |
Front NC Coils | Short to ground or open solenoid |
C0160 |
A160 |
Rear NO Coils | Short to battery |
C0161 |
A161 |
Rear NO Coils | Short to ground or open solenoid |
C0170 |
A170 |
Rear NC Coils | Short to battery |
C0171 |
A171 |
Rear NC Coils | Short to ground or open solenoid |
A200 |
CAN Bus | No communication between ABS ECU and dashboard |
C0210 |
A210 |
Warning Lamp Output | Short to battery |
C0213 |
A213 |
Warning Lamp Output | Short to ground or open |
C0230 |
A230 |
Vehicle Speed Output | Short to ground |
C0231 |
A231 |
Vehicle Speed Output | Short to battery |
